Searching the web using your voice
Using the Google voice assistant widget, you can ask your device to search the web for you using your voice without having to touch your device.
- 1.
From the Home screen, tap the Assistant icon in the Google search widget.
Step 1/3 - 2.
Speak your search terms.
Note: If the device understands your search term, your results will be displayed.
Step 2/3 - Step 3 of 3:
You've completed the steps!
Step 3/3
