Switching between calls
While on a phone call, you may receive a second phone call. You can put one phone call on hold and talk to other other and switch between them.
- 1.
During an ongoing call, tap the green Call icon to answer the incoming call.
Note: This will put the original call on hold.
Step 1/4 - 2.
Select the call on hold to return to it.
Step 2/4 - 3.
Tap the End Call icon to end the current call.
Note: When you end one call, you'll automatically switch to the other call that was on hold.
Step 3/4 - Step 4 of 4:
You've completed the steps!
Step 4/4
