Using Multi-window
You can multitask with two applications on your device by using split screen. This will allow you to have two apps open at once.
- Step 1/5
From the Home screen, swipe up from the bottom of the screen and hold to access your recent apps.
- Step 2/5
Tap the Multi-window icon above an app.
- Step 3/5
Select another app to view in split screen.
- Step 4/5
To exit an application in split-screen, swipe up from the bottom of the screen.
- Step 5/5Step 5 of 5:
You've completed the steps!
Was this tutorial helpful?
