Creating a group and adding contacts to It
Create a group to combine contacts that you typically contact together. You will be able to select the group as you would a contact for text messaging.
- Step 1/9
From the Contacts tab, tap Groups.
- Step 2/9
Tap New.
- Step 3/9
Tap the New group field.
- Step 4/9
Enter the group's name.
- Step 5/9
Tap OK.
- Step 6/9
Tap Add members.
- Step 7/9
Select a contact.
- Step 8/9
Tap Add.
Note: To add more contacts to the group, repeat steps 6-8.
- Step 9/9Step 9 of 9:
You've completed the steps!
Was this helpful?
