Finding your Smart Switch device PIN
Samsung Galaxy XCover 4 on Android 9.0.0
Copy link
If you're having difficulty connecting your device for a content transfer, you may need to use your device PIN to establish a manual connection. Find out where you can find your Smart Switch device PIN to establish a manual connection.
  1. Note: If you're having difficulty connecting your device for content transfer, you may need to establish a manual connection using your device PIN.
  2. Step 1/8
  3. Step 2/8
    Tap the Settings icon.
  4. Step 3/8
    Scroll to Accounts and backup
  5. Step 4/8
    Tap Accounts and backup.
  6. Step 5/8
    Tap Smart Switch.
  7. Step 6/8
    Tap the Menu icon.
  8. Step 7/8
    Tap Settings.
    Note: On the next screen you should find your device PIN as well as some additional transfer security options.
  9. Step 8/8
    Step 8 of 8:
    You've completed the steps!
Was this tutorial helpful?
