Using Multi Window™
Samsung Galaxy XCover 4 on Android 9.0.0
You can multitask with two applications on your device by using split screen. This will allow you to have two apps open at once.
- Step 1/7
From the Home screen, tap the Recent Apps icon.
- Step 2/7
Tap the App icon.
- Step 3/7
Tap Open in split screen view.
- Step 4/7
Select another app to view in split screen.
- Step 5/7
To exit Multi Window, tap the Home button.
- Step 6/7
Tap the X icon.
- Step 7/7
You've completed the steps!
Was this helpful?
