Adding and changing a Lock screen shortcut
Samsung Galaxy XCover 4 on Android 9.0.0
Copy link
Some apps can be accessed quickly from your lock screen. You can change the apps that appear on the lock screen for quick access.
  1. Step 1/8
  2. Step 2/8
    Tap the Settings icon.
  3. Step 3/8
    Tap Lock screen.
  4. Step 4/8
    Scroll to App shortcuts.
  5. Step 5/8
    Tap App shortcuts.
  6. Step 6/8
    Select a shortcut location.
  7. Step 7/8
    Select the Lock screen shortcut you'd like to use.
  8. Step 8/8
    Step 8 of 8:
    You've completed the steps!
Was this tutorial helpful?
