PhoneUsing Multi Window™
You can multitask with two applications on your device by using split screen. This will allow you to have two apps open at once.
Current Step: 1 - From the Home screen, swipe up and hold from the bottom of the screen to access your recent apps.
  1. 1 - From the Home screen, swipe up and hold from the bottom of the screen to access your recent apps.
  2. 2 - Touch and hold the icon of an app you'd like to view in Multi Window.
  3. 3 - Tap Split screen.
  4. 4 - Select another app to view in split screen.
  5. 5 - To exit Multi Window, drag the split screen bar to the top or bottom of the screen.
1/6
