PhoneUsing turn-by-turn navigation
The Maps application can help guide you to your destination with turn-by-turn navigation. You can also use the Maps app to search for nearby places such as restaurants or grocery stores.
Current Step: 1 - From the Home screen, swipe up the Home icon halfway to view your recent apps.
  1. 1 - From the Home screen, swipe up the Home icon halfway to view your recent apps.
  2. 2 - Swipe up the Home icon again to view your apps.
    • Note: Performing a full swipe up on the Home icon will show your apps tray.
  3. 3 - Tap Maps.
  4. 4 - Tap GO.
  5. 5 - Tap the Choose destination field.
    • Note: You can get car, bus, cycling or walking directions.
  6. 6 - Enter a destination.
  7. 7 - Select your destination from the list.
  8. 8 - Tap Start to begin navigating toward the destination.
  9. 9 - You've completed the steps!
1/9
