WF721 Wireless Home PhoneDisabling Call Forwarding
You can turn call forwarding on directly from your keypad. Call forwarding lets you forward incoming calls to another phone.
Current Step: 1 - To disable call forwarding for all calls, enter "##21#" on the connected phone.
  1. 1 - To disable call forwarding for all calls, enter "##21#" on the connected phone.
    • Remarque : To disable call forwarding for busy calls, enter "##67#" instead. To disable call forwarding for unanswered calls, enter "##61#".
  2. 2 - Listen for the confirmation tone before hanging up.
  3. 3 - You've completed the steps!
1/3
