Pixel 5Checking your mobile or Wi-Fi signal
If you're having problems such as slow data speeds, dropped calls or audio issues, your mobile or Wi-Fi signal may be the cause.
Current Step: 1 - Check to see if there is a sufficient mobile signal on the phone by looking at the signal bars in the status bar. The more bars that are displayed, the better the connection.
1/3
Step 1
Answer Feedback Form
Was this information helpful?
