Pixel 3a XLFinding additional help
You can use your device's help documents to find more help or information for your device.
  2. 2 - Drag down the Quick settings panel.
  3. 3 - Tap the Settings icon.
  4. 4 - Scroll to Tips & support.
  5. 5 - Tap Tips & support.
    • Note: After this step, you'll find tutorials to help you get the most out of your device.
1/6
