Pixel 3Enabling sound notifications
Sound Notifications help you know what happens in your home. When Sound Notifications are on, your phone will always check for sounds you want notifications about, like when a smoke alarm beeps or a doorbell rings.
  2. 2 - Drag down the Quick settings panel.
  3. 3 - Tap the Settings icon.
  4. 4 - Scroll to Accessibility.
  5. 5 - Tap Accessibility.
  6. 6 - Scroll to Sound Notificaions.
  7. 7 - Tap Sound Notifications.
  8. 8 - Tap or slide the Sound Notifications shortcut switch to ON.
  9. 9 - Tap OK.
  10. 10 - Tap Settings.
  11. 11 - Tap Open Live Transcribe.
    • Remarque : Live Transcribe transcribes what happens after a sound is detected.
  12. 12 - You've completed the steps!
1/12
