Pixel 2Changing roaming settings for a trip
When traveling internationally, you may want to turn data roaming on and off to conserve data and minimize unwanted fees.
  2. 2 - Drag down the Quick settings panel.
  3. 3 - Tap the Settings icon.
  4. 4 - Tap Network & internet.
  5. 5 - Tap Mobile network.
  6. 6 - Tap or slide Roaming switch to ON.
    • Remarque : Turning Data roaming on allows you to connect to data services while roaming. Turn Data roaming off to keep from incurring significant charges.
  7. 7 - Tap OK.
  8. 8 - Tap Preferred network type.
  9. 9 - Select your preferred setting.
  10. 10 - You've completed the steps!
1/10
