Pixel 2 XLUsing power saving mode
Use emergency power saving mode when your device is low on battery and you still need to be able use some functions on your device.
Battery running low? Check out our batteries, chargers, adapters and cables.
    • Remarque : Battery Saver saves battery power by turning off some device features and restricting apps.
  2. 2 - Touch and hold the Battery icon.
  3. 3 - Tap Battery Saver.
  4. 4 - Tap or slide the Turn off when fully charged switch to ON.
  5. 5 - You've completed the steps!
1/5
