Understanding the device buttons and features
Motorola Moto Z on Android 8.0.0
Copy link
Explore an interactive view of the front of your device. Learn about various icons, buttons, and features and where they're located.
  • Select a yellow indicator on the image or an item from the list to learn more about that feature.
    Scroll to learn more about each feature.
    The indicator is in the bottom left.
  • Back icon: Used to go back one screen.
  • Earpiece speaker: Listen to audio or phone calls from here.
  • Fingerprint sensor: Used for unlocking the device with your fingerprint.
  • Front camera: Used for taking pictures and recording videos.
    The indicator is in the top left.
  • Home icon: Takes you to the last Home screen you were on. If you're on a Home screen, it will take you to the main Home screen. Touch and hold for Google Assistant.
  • Microphone: Built-in microphone used for phone calls and voice commands.
  • Nano SIM / microSD card slot: Insert or remove your nano SIM / microSD card here.
  • Power/Lock button: Press to lock or unlock the touchscreen. Hold down to turn the device on or off.
  • Recent Apps icon: Shows the apps you've recently opened, letting you switch between and close apps that are running. Touch and hold to enter split screen mode.
  • Touchscreen: Used to navigate your device.
  • USB/Charging port: Connects your phone to the battery charger or to another device for transferring data.
  • Volume buttons: Adjusts the volume on your device.
Was this tutorial helpful?
