iPhone 8 PlusUsing Magnifier to help view nearby objects
Magnifier turns your iPhone or iPad into a magnifying glass, zooming in on objects near you and helping you detect nearby doors and people.
Current Step: 1 - Within the Magnification app, swipe left on the Options bar to view your extra options.
The preinstalled Magnifier app can be found in your iPhone's App Library. Otherwise, you can download Apple's free, official app from from the App Store.
  1. 1 - Within the Magnification app, swipe left on the Options bar to view your extra options.
    • Note: You can add or remove the options in the menu by tapping on the Settings cog icon.
  2. 2 - To zoom in or out, swipe up or down on the zoom bar.
  3. 3 - Tap the Capture icon to take a photo.
    • Note: Your captured images will not save to your photo library.
  4. 4 - You've completed the steps!
1/4
