iPhone 7Configuring location settings
Current Step: 1 - From the Home screen, tap Settings.
  1. 1 - From the Home screen, tap Settings.
  2. 2 - Scroll to Privacy.
  3. 3 - Tap Privacy.
  4. 4 - Tap Location Services.
  5. 5 - Tap or slide the Location Services switch to ON.
    • Note: If you turn Location Services off, you won't be able to use apps or features that require your location.
  6. 6 - Select an app.
  7. 7 - Select your location access preference.
  8. 8 - You've completed the steps!
1/8
