Configuring location settings
Apple iPhone 6S Plus on iOS 15.4.0
- Step 1/8
From the Home screen, tap Settings.
- Step 2/8
Scroll to Privacy.
- Step 3/8
Tap Privacy.
- Step 4/8
Tap Location Services.
- Step 5/8
Tap or slide the Location Services switch to ON.
Note: If you turn Location Services off, you won't be able to use apps or features that require your location.
- Step 6/8
Select an app.
- Step 7/8
Select your location access preference.
- Step 8/8
You've completed the steps!
Was this helpful?
