iPhone 6S PlusSetting up Face ID
Set up the Face security type lock to help keep your device secure. If your face is not recognized by the device, you will be prompted to input your PIN or passcode.
Current Step: 1 - From the Home screen, tap Settings.
  1. 1 - From the Home screen, tap Settings.
  2. 2 - Scroll to Face ID & Passcode.
  3. 3 - Tap Face ID & Passcode.
    • Note: If necessary, enter your passcode. You're required to set up a passcode in order to use Face ID.
  4. 4 - Tap Set Up Face ID.
    • Note: For this tutorial, we're showing how to set up Face ID. You can also set up your phone to unlock only using a passcode, but steps may vary based on what you choose.
  5. 5 - Tap Get Started.
  6. 6 - With your face positioned within the camera frame, slowly rotate your head in a circle.
  7. 7 - Tap Continue.
  8. 8 - With your face positioned within the camera frame, slowly rotate your head in a circle.
  9. 9 - Tap Done.
    • Note: If necessary, enter and confirm a passcode to use when Face ID is not available.
  10. 10 - Press the Side button to put iPhone to sleep.
  11. 11 - Press the Side button to wake iPhone.
    • Note: You must be looking at iPhone to activate Face ID.
  12. 12 - Swipe up from the bottom of your screen to unlock iPhone.
  13. 13 - You've completed the steps!
1/13
