Skip to contentSkip to search
iPad (5th generation)Using Picture in Picture
With the Picture-in-Picture function of your device, you can keep a minimized version of some apps open while you navigate the rest of your device.
Current Step: 1 - From a full screen video, swipe up from the bottom of the screen to access the home screen.
  1. 1 - From a full screen video, swipe up from the bottom of the screen to access the home screen.
    • Note: If your device has a home button, press the Home button instead of swiping.
  2. 2 - Drag the video to the desired location.
  3. 3 - Tap Settings.
    • Note: You can access other apps while your video is playing.
  4. 4 - Tap the video to bring up options.
  5. 5 - Tap the Picture in Picture icon to go back to full screen mode.
1/6
Answer Feedback Form
Was this information helpful?
