iPad (5th generation)Using Control Center
You have quick access to many of your device's features from your control center. Access your control center from the home screen and use it to do things like turn on or off the flashlight, start a time, access the calculator or camera, and more.
Current Step: 1 - From the Home screen, drag down from the top right portion of your screen.
  1. 1 - From the Home screen, drag down from the top right portion of your screen.
  2. 2 - Press and hold the Timer icon to view Timer quick settings.
  3. 3 - Tap outside of the Timer meter to return to the Control Center.
  4. 4 - Slide the Sound meter up or down to adjust iPad volume.
  5. 5 - You've completed the steps!
1/5
