Skip to contentSkip to search
ONETOUCH Idol 3Checking for and Installing System Updates
You can check for system updates on your device to make sure you are up to date with your software. Using the newest software can help keep your device healthy.
  2. 2 - Drag down the Quick Settings panel.
  3. 3 - Tap the Settings icon.
  4. 4 - Scroll to About phone.
  5. 5 - Tap About phone.
  6. 6 - Tap Updates.
  7. 7 - Tap the Update button to check for updates.
  8. 8 - You've completed the steps!
1/8
Answer Feedback Form
Was this information helpful?
