Skip to contentSkip to search
ONETOUCH Idol 3Changing Roaming Settings for a Trip
When traveling internationally, you may want to turn data roaming on and off to conserve data and minimize unwanted fees.
  2. 2 - Drag down the Quick Settings panel.
  3. 3 - Tap the Settings icon.
  4. 4 - Tap More.
  5. 5 - Tap Cellular networks.
  6. 6 - Tap Data roaming.
  7. 7 - Select a data roaming preference.
  8. 8 - Tap OK.
  9. 9 - You've completed the steps!
1/9
Answer Feedback Form
Was this information helpful?
