Accessing Settings
Samsung Galaxy S6 Edge on Android 7.0.0
Your device settings lets you change options for things such as alert sounds, turn on or off GPS, adjust network settings, change the time, and more.
  1. Step 1/3
  2. Step 2/3
    Tap the Settings icon.
  3. Step 3/3
    You've completed the steps!
Was this helpful?
