Setting the Phone to Silent
Samsung Galaxy S6 Edge on Android 7.0.0
Silent mode will quiet your device's notifications. When your device is in silent mode, it will not make a sound to notify you of incoming notifications. You can set it to vibrate to alert you to incoming notifications with vibrations instead of sound.
- Step 1/5
- Step 2/5
Drag down the Quick settings panel.
- Step 3/5
Tap the Sound icon.
- Step 4/5
Tap the Vibrate icon.
- Step 5/5
You've completed the steps!
Was this helpful?
