Changing Settings
Samsung Galaxy S6 Edge on Android 7.0.0
Copy link
Adjust your Google Now settings so your Google Now feed will be customized to your needs.
  1. Step 1/5
    From the Google Now app main screen, tap the Navigation icon.
    The indicator is in the top left.
  2. Step 2/5
    Tap Settings.
    The indicator is towards the left.
  3. Step 3/5
    Tap Accounts & privacy.
  4. Step 4/5
    Switch Open web pages in app to OFF.
  5. Step 5/5
    Step 5 of 5:
    You've completed the steps!
Was this tutorial helpful?
