Using Turn-by-Turn Directions
Samsung Galaxy S6 Edge on Android 7.0.0
Copy link
The Maps application can help guide you to your destination. Learn how to use Maps on your device to navigate to any location with turn-by-turn directions.
  1. Step 1/8
    From the Home screen, tap Google.
  2. Step 2/8
    Tap Maps. If necessary, read and tap through any first-time use screens.
    The indicator is towards the left.
  3. Step 3/8
    Tap the GO icon.
  4. Step 4/8
    Tap the Choose destination field.
  5. Step 5/8
    Enter a destination.
    The indicator is in the bottom left.
  6. Step 6/8
    Select a result.
  7. Step 7/8
    Tap the START icon to begin navigating.
  8. Step 8/8
    Step 8 of 8:
    You've completed the steps!
Was this tutorial helpful?
