Understanding the Device Buttons and Features
Samsung Galaxy S6 Edge on Android 7.0.0
Explore an interactive view of the front of your device. Learn about various icons, buttons, and features and where they're located.
Select a yellow indicator on the image or an item from the list to learn more about that feature.
Scroll to learn more about each feature.
Audio/Headphone Jack: Used to plug in your headset or headphones.
Back Button: Navigates to the previous screen.
Earpiece Speaker: Plays audio and lets you hear phone calls.
Home Button: Navigates you to the default Home screen.
Microphone: Built-in microphone used for phone calls and voice commands.
Nano SIM Card Tray: Insert or remove your nano SIM card here.
Power/Lock Button: Press to lock or unlock the touchscreen. Hold down to turn the device on or off.
Recent Apps Button: Opens a list of the apps you've opened recently.
Touchscreen: Used to navigate your device.
USB/Charging Port: Used to charge your battery and connect your phone to other devices.
Volume Buttons: Adjusts the volume on your device.
Was this helpful?
