Changing Message Settings
Samsung Galaxy S6 Edge Plus on Android 7.0.0
Change the text messaging settings for your device. You can change your notification settings, change your default SMS app, auto-download MMS text, and more.
- Step 1/7
From the Messages app main screen, tap the Menu icon.
- Step 2/7
Tap Settings.
- Step 3/7
Tap Backgrounds.
- Step 4/7
Swipe to a background.
- Step 5/7
Select a background.
- Step 6/7
Tap the Back button to save changes.
- Step 7/7
You've completed the steps!
Was this helpful?
