Using a Pattern Lock
Samsung Galaxy S6 Edge Plus on Android 7.0.0
Your device can be secured using a pattern that you draw on the lock screen. No one will be able to get into your device without knowing the pattern. If you forget your pattern you will have to reset your device and you will lose any information that is not backed up.
- 1.
Step 1/12 - 2.
Tap the Settings icon.
Step 2/12 - 3.
Tap Lock screen and security.
Step 3/12 - 4.
Tap Screen lock type.
Step 4/12 - 5.
Tap Pattern.
Step 5/12 - 6.
Enter your pattern.
Step 6/12 - 7.
Tap CONTINUE.
Step 7/12 - 8.
Confirm your pattern.
Step 8/12 - 9.
Tap CONFIRM.
Step 9/12 - 10.
Tap DONE.
Step 10/12 - 11.
Tap LATER.
Step 11/12 - Step 12 of 12:
You've completed the steps!
Step 12/12
