Changing Roaming Settings for a Trip
Samsung Galaxy S6 Edge Plus on Android 7.0.0
When traveling internationally, you may want to turn data roaming on and off to conserve data and minimize unwanted fees.
  1. Step 1/6
  2. Step 2/6
    Tap the Settings icon.
  3. Step 3/6
    Tap Connections.
    The indicator is in the top left.
  4. Step 4/6
    Tap Mobile networks.
  5. Step 5/6
    Switch Data roaming to ON.
  6. Step 6/6
    Step 6 of 6:
    You've completed the steps!
Was this helpful?
