Accessing Mobile Network Settings
Samsung Galaxy S6 Edge Plus on Android 7.0.0
When traveling internationally, your device settings may require an update to conserve data and minimize unwanted fees. Learn how to change roaming settings on your device ahead of your next international trip, including how to enable and disable roaming.
- Step 1/5
- Step 2/5
Tap the Settings icon.
- Step 3/5
Tap Connections.
- Step 4/5
Tap Mobile networks.
- Step 5/5Step 5 of 5:
You've completed the steps!
Was this helpful?
