Galaxy J3 PrimeUsing a pattern Lock
Your device can be secured using a pattern that you draw on the lock screen. No one will be able to get into your device without knowing the pattern. If you forget your pattern you will have to reset your device and you will lose any information that is not backed up.
  2. 2 - Tap the Settings icon.
  3. 3 - Scroll to Lock screen.
  4. 4 - Tap Lock screen.
  5. 5 - Tap Screen lock type.
  6. 6 - Tap Pattern.
    • Note: For this tutorial, we're showing how to set up a pattern. You can select a different type of security, but steps may vary based on what you choose.
  7. 7 - Enter your pattern.
    • Note: Your pattern must connect at least 4 dots.
  8. 8 - Tap CONTINUE.
  9. 9 - Confirm your pattern.
  10. 10 - Tap CONFIRM.
  11. 11 - Select a notification preference.
    • Note: Tap Hide content to prevent the content of emails, texts and other notifications from appearing on the Lock screen. You'll be notified that you have a new message, but not shown what the message contains.
  12. 12 - Tap DONE.
  13. 13 - You've completed the steps!
1/13
