Galaxy A8 (2018)Changing roaming settings for a trip
When traveling internationally, you may want to turn data roaming on and off to conserve data and minimize unwanted fees.
  2. 2 - Tap the Settings icon.
  3. 3 - Tap Connections.
  4. 4 - Tap Mobile networks.
  5. 5 - Tap or slide the Data roaming switch to ON.
    • Remarque : Turning Data roaming on allows you to connect to data services while roaming. Turn Data roaming off to keep from incurring significant charges.
1/6
