Using turn-by-turn navigation
LG G7 ThinQ on Android 10.0.0
The Maps application can help guide you to your destination with turn-by-turn navigation. You can also use the Maps app to search for nearby places such as restaurants or grocery stores.
- Step 1/8
From the Home screen, tap the Google folder.
- Step 2/8
Tap Maps.
Note: If necessary, read any first-time use screens and tap ACCEPT & CONTINUE.
- Step 3/8
Tap GO.
- Step 4/8
Tap the Choose destination field.
- Step 5/8
Enter a destination.
- Step 6/8
Select a result.
- Step 7/8
Tap Start to begin navigating.
- Step 8/8
You've completed the steps!
Was this helpful?
