Changing roaming settings for a trip
LG G7 ThinQ on Android 10.0.0
When traveling internationally, you may want to turn data roaming on and off to conserve data and minimize unwanted fees.
  1. Note: Roaming allows you to continue your data connection outside of your main coverage area. You can set access to Data Roaming while you're on a trip.
  2. Step 1/5
    From the Home screen, tap Settings.
  3. Step 2/5
    Tap Network & internet.
  4. Step 3/5
    Tap Mobile networks.
    Note: Turning data roaming on allows you to connect to data services while roaming. Turn data roaming off to keep from incurring significant charges.
  5. Step 4/5
    Tap or slide the Data roaming switch to ON.
  6. Step 5/5
    You've completed the steps!
Was this helpful?
