G7 OneUsing power saving mode
Use emergency power saving mode when your device is low on battery and you still need to be able use some functions on your device.
1/4
Step 1
Note: Power saving mode saves battery power by limiting access to certain apps, including the flashlight. You can also send your location or a text message to an emergency contact.
Answer Feedback Form
Was this information helpful?
