Changing Account Settings
LG X Power on Android 6.0.1
When you set up an email account on your device, it may also sync your contacts or your calendar to your device. You can change those settings to only sync the data from the account that you want on the device.
  1. Step 1/7
    From the Home screen, drag down the Notification Panel.
  2. Step 2/7
    Tap the Settings icon.
  3. Step 3/7
    Scroll to Accounts & sync.
  4. Step 4/7
    Tap Accounts & sync.
    The indicator is towards the left.
  5. Step 5/7
    Select the account type.
  6. Step 6/7
    Select your preferences.
  7. Step 7/7
    Step 7 of 7:
    You've completed the steps!
Was this helpful?
