Skip to contentSkip to search
X power3Creating folders
Creating folders on your Home Screen can help keep you organized. You can create folders for categories of apps such as Banking, Travel, Utilities, Social Media and more to customize your device.
Current Step: 1 - From the Home screen, touch and hold an app.
  1. 1 - From the Home screen, touch and hold an app.
  2. 2 - Drag the app on top of another app.
  3. 3 - Tap the folder.
  4. 4 - Tap the Folder field.
  5. 5 - Enter a name for the folder.
  6. 6 - Select a color for the folder.
  7. 7 - Tap OK.
    • Note: To remove an app from the folder, touch and hold an icon, and then drag it out of the folder.
  8. 8 - You've completed the steps!
1/8
Answer Feedback Form
Was this information helpful?
