Connecting a Phone to the Device
ZTE WF721 Wireless Home Phone on Other 1.0.1
Copy link
Learn how to connect a phone directly to your device using the telephone port.
  1. Step 1/3
    Slide the Power Switch on the back of the device to the ON position.
    The indicator is in the bottom left.
  2. Step 2/3
    Insert the phone cable into the Telephone port on the back of the device.
    Note: To check that the device is working correctly, you should be able to hear a dial tone on the phone you connected.
  3. Step 3/3
    Step 3 of 3:
    You've completed the steps!
Was this tutorial helpful?
