Enabling Call Forwarding
ZTE WF721 Wireless Home Phone on Other 1.0.1
You can turn off call forwarding on directly from your keypad. Call forwarding lets you forward incoming calls to another phone.
  1. Note: Call forwarding lets you forward incoming calls to another phone.
  2. Step 1/5
    To forward all incoming calls, enter "**21*" on the connected phone when not on a call.
    Note: You can also enter "67*" to forward calls when you are busy, or "61*" to forward calls that go unanswered.
  3. Step 2/5
    Enter the phone number you would like to forward your calls to.
    Note: The phone number must contain 10 digits.
  4. Step 3/5
    Press the # button.
  5. Step 4/5
    Listen for the confirmation tone.
    Note: After this step, you may hang up.
  6. Step 5/5
    You've completed the steps!
Was this helpful?
