Pixel 3a XLConfiguring location settings
  2. 2 - Drag down the Quick settings panel.
  3. 3 - Tap the Settings icon.
  4. 4 - Scroll to Location.
  5. 5 - Tap Location.
  6. 6 - Tap or slide the Use location switch to ON.
    • Remarque : If you turn Location Services off, you won't be able to use Google Maps or any other apps or features that require your location.
    • Remarque : You can also choose which apps will have access to your location.
  7. 7 - To manage individual app permissions, tap App location permissions.
  8. 8 - Select an app you'd like to modify the permissions for.
  9. 9 - Select your preferred location access setting.
  10. 10 - You've completed the steps!
1/10
