Pixel 3a XLManaging the battery
Learn how to manage the battery on your device. Taking care of your battery will extend your battery life.
  2. 2 - Drag down the Quick settings panel.
  3. 3 - Swipe to Battery saver.
  4. 4 - Touch and hold Battery saver.
  5. 5 - Tap Battery usage.
    • Remarque : From this screen, you can view details about how your battery power is being used.
  6. 6 - Select an app to view more information.
  7. 7 - Swipe from the left or right edge of the screen.
  8. 8 - Swipe from the left or right edge of the screen again.
  9. 9 - Tap Adaptive preferences.
  10. 10 - Tap or slide the Adaptive Charging switch to ON.
    • Remarque : Adaptive Charging preserves long-term battery life by charging steadily.
  11. 11 - You've completed the steps!
1/11
