Using TalkBack
Use the TalkBack function on your device to help you navigate it by touch. The device will speak what is on the screen an you can tap anywhere on the screen to tap the item that is being spoken.
Note: TalkBack provides spoken feedback so that you can use your device without viewing the screen. This feature is helpful for individuals with blindness or visual impairments.
- Step 1/15
From the Home screen, tap Settings.
- Step 2/15
Scroll to Accessibility features.
- Step 3/15
Tap Accessibility features.
- Step 4/15
Tap Accessibility.
- Step 5/15
Tap TalkBack.
- Step 6/15
Tap More settings.
- Step 7/15
Select your preferences.
Note: From this screen, you can adjust TalkBack settings including sound volume, spoken passwords, and more.
- Step 8/15
Swipe from the left or right edge of the screen to go back.
- Step 9/15
Tap or slide the TalkBack switch to ON.
- Step 10/15
Tap OK.
- Step 11/15
Swipe from left to right until the TalkBack switch is selected.
Note: Swiping left and right navigates between items read aloud. Using two fingers allows users to scroll.
- Step 12/15
Quickly tap the screen twice to activate the selected item.
Note: Performing a double-tap activates the selected item.
- Step 13/15
Swipe from left to right until OK is selected.
- Step 14/15
- Step 15/15Step 15 of 15:
You've completed the steps!
Was this helpful?
