Using Near Field Communication and Android Beam™
Turn on Near Field Communications to send data to a near by device that also has NFC enabled. You can send pictures, contact information, GPS locations, and more.
Note: With Near Field Communication (NFC), you can instantly share content like web addresses, contact info, Google Play Store apps, GPS locations and more to another Android NFC-capable device.
- 1.
From the Home screen, tap Settings.
Step 1/5 - 2.
Tap More connections.
Step 2/5 - 3.
Tap NFC.
Step 3/5 - 4.
Tap or slide the NFC switch to ON.
Step 4/5 - Step 5 of 5:
You've completed the steps!
Step 5/5
