Configuring location settings
- Step 1/5
From the Home screen, tap Settings.
- Step 2/5
Scroll to Location.
- Step 3/5
Tap Location.
- Step 4/5
Tap or slide the Access my location switch to ON.
Note: If you turn Location Services off, you won't be able to use Google Maps or any other apps or features that require your location.
Note: You can also choose which apps will have access to your location.
- Step 5/5Step 5 of 5:
You've completed the steps!
Was this tutorial helpful?
