Enabling USB debugging
Turn on USB Debugging to help trouble shoot your device. Once USB Debugging is turned on, you will be able to plug your device into a computer to access your device's logs.
- Step 1/11
From the Home screen, tap Settings.
- Step 2/11
Scroll to About phone.
- Step 3/11
Tap About phone.
- Step 4/11
Tap Build number seven times.
Note: You may be prompted to enter your device PIN or password. When Developer options has been enabled successfully, you will see a message at the bottom of the screen which states Developer mode has been enabled.
- Step 5/11
Swipe from the left or right edge of the screen to go back.
- Step 6/11
Tap System & updates.
- Step 7/11
Tap Developer options.
- Step 8/11
Scroll to USB debugging.
- Step 9/11
Tap or slide the USB debugging switch to ON.
- Step 10/11
Tap OK.
- Step 11/11Step 11 of 11:
You've completed the steps!
Was this tutorial helpful?
