Managing the battery
Learn how to manage the battery on your device. Taking care of your battery will extend your battery life.
- Step 1/12
From the Home screen, tap Settings.
- Step 2/12
Scroll to Battery.
- Step 3/12
Tap Battery.
- Step 4/12
Tap Battery usage.
Note: From this screen, you can view details about how your battery power is being used.
- Step 5/12
Select an app to view more information.
- Step 6/12
Swipe from the left or right edge of the screen to go back.
- Step 7/12
Swipe from the left or right edge of the screen to go back again.
- Step 8/12
Tap OPTIMIZE BATTERY USAGE.
- Step 9/12
Tap OPTIMIZE to enable a battery optimization recommendation.
- Step 10/12
Tap FINISH.
- Step 11/12
Tap or slide the Power saving mode switch to ON.
Note: Power saving mode saves battery power by limiting access to certain apps, including the flashlight.
- Step 12/12Step 12 of 12:
You've completed the steps!
Was this tutorial helpful?
