Using picture-in-picture
With the Picture-in-Picture function of your device, you can keep a minimized version of some apps open while you navigate the rest of your device.
- 1.
From an ongoing navigation in Maps, swipe from the bottom edge of the screen to return to the home screen.
Note: In this tutorial we're using picture-in-picture for Maps navigation. However, you may wish to use a video app instead. The steps are essentially the same, but you may encounter minor variations based on the app you select.
Step 1/5 - 2.
Drag the Picture-in-picture window to a new location on your screen.
Step 2/5 - 3.
Tap the Picture-in-picture window.
Step 3/5 - 4.
Tap the Fullscreen icon to return to fullscreen.
Note: You can dismiss your Picture-in-Picture window by dragging it to the bottom of your screen or tapping the X icon.
Step 4/5 - Step 5 of 5:
You've completed the steps!
Step 5/5
